03-22-2013, 07:55:38 PM
#76
I'm anxious to here how satisfied you are with the motor. I've been thinking about building a 400. You have been very busy over the last couple of years. Great progress. My parents have a place in Sarasota, I will have to look you up when I come down there.
03-23-2013, 08:08:00 PM
#77
Unreal!
03-23-2013, 08:14:34 PM
#78
Dude what a save with this car. WOW
Tim
2005 Magnum R/T
2004 GTO 6sp
1993 Silverado Z71
1970 Camaro SS350
03-24-2013, 01:17:55 PM
#79
Looks great! A+++ what is your bore & stroke on the motor
03-25-2013, 09:22:10 AM
#80
Guys-
Thanks for the kind words. Since thes last pics I've added the accessory drive, and fired the motor for the first time. I had a leak from what I thought was the input shaft seal on the transmission. After pulling the trans twice, I found it was actually a pin hole in the weld where the hub welds to the torque converter... I got way more parctice pulling the trans than I will ever need lol...
Anyway, no leaks for now. I will get some new pic's up soon.
I don't know the actual bore and stroke specs off the top of my head, I will post them as well.
03-25-2013, 03:00:10 PM
#81
Super job on everything. A+ on the attention to detail and the determination for such a long project. You have just set a new standard to the term " savable".
03-25-2013, 11:19:02 PM
#82
Always admired metal men and gear heads as yourself. Impressive what skill and talent can do.
1971RS, orig 350 (8.5:1),heads,2.73 79 (trans,crane 113941,450cfm Holley,SP-2P intake,headers,Accel 41000 ign) 86-87 paint,vinyl top,interior 88-2012: garage abandon 2012 Oct (trans,1st bore .003,CompCam 12-238-2,HEI,headers,pipes)
Project http://www.nastyz28.com/forum/showthread.php?t=252900
03-26-2013, 09:13:57 AM
#83
$ Mike Z28-
We ended up at a 4.155 bore (.030 over) and a 3.875 Stroke. I can post all of the other specs if anyone is interested.
Thanks for the props, there are a ton of talented guys on here that inspire me to keep motivated!
03-26-2013, 10:55:09 AM
#84
I would be interested in the specs if you post them. Again great work on the car. Looking good!!
03-27-2013, 05:55:39 PM
#85
Motor specs are:
400 small block .030 overbore
Eagle 4340 internal balance crank, 3.875 stroke
Callies 4340 H beam rods, 5.850"
SRP pistons, 16CC dish
Hastings rings
9.6:1 Compression
ARP main studs
Cloyes adjustable timing set
Comp cams Xtreme Energy retro fit roller cam 1.050 base circle
Comp 1.6 rockers
intake .520 lift (.555 w/ 1.6 rocker) 236 duration @ .050
Exhaust .540 lift (.576 w/ 1.6 rocker) 242 duration @ .050
AFR 195cc heads 65cc chamber
2.05 Intake, 1.60 Exhaust
ARP 7/16 rocker studs
AFR stud girdle
Edelbrock port matched Victor Jr intake
Scat SFI Flexplate
M55HV oil pump
Powerforce Plus SFI balancer
Milodon 7 qt oil pan
This combo should be worth 550-600 horse, and be a torque monster. Sucks that it's going to be a while befor I can drive it. Worse than waiting for christmas....
03-28-2013, 09:58:55 AM
#86
That's a killer recipe!
