Old 06-14-2014, 12:41:56 PM   #496
flak monkey
flak monkey's Avatar
Couple more bits of progress today. The headers arrived, doesn't look too difficult to modify them to work with the external wastegates.
And I collected a 4L80E too, just needs rebuilding and the output shaft and housing swapping for a 2wd version. Having looked at the parts it's easy to see why they will take so much more power than the 700r4. In hindsight I would have been better off just fitting one of those in the first place, but never mind!
I am considering whether to go the whole hog and build the motor using a Dart block, certainly makes it future proof. Will see how the cash flow goes.
My '80 progress thread
Our Bonneville Adventures follow the progress on Facebook
flak monkey is offline   Reply With Quote
Old 06-22-2014, 03:19:19 PM   #497
flak monkey
I got a serpentine belt system with my new block, been messing around with it today. Its one from a '90 G20 van, steel brackets. Not as pretty as the cast aluminum ones, but there ya go. Got all the accessories with it too, including a nice 120 amp CS alternator. More or less figured out how it all fits together.
Been having issues with my PS pump belt slipping since getting the car back on the road, so want to try and get the serpentine set up fitted to see how it performs. If all is OK then I'll transfer it to my turbo set up.
I've ordered an AC delete idler, which I hope will fit, if not I'll be making a suitable one. Just need to find a new reverse rotation water pump and a few other odds before fitting it all up.
Old 06-28-2014, 01:42:46 PM   #498
flak monkey
Finally got around to applying some stickers today
Also spent a couple of hours swapping out the injectors to the new 70lb ones I got. Runs OK, still some fine tuning to do but it idles good and isnt running out of duty cycle now!
Also did a bit more work on the serpentine drive, just got to get a PS pump for it. Before that I ought to check it will actually fit under the hood, I reckon alternator clearance will be very tight! Anyone else tried one of these?
Old 07-08-2014, 03:32:43 PM   #499
flak monkey
Slow progress - time and money (mostly money) is the main constraint.
Spent an hour or so measuring the cylinder wall thicknesses on my block - was a little concerned as its at +.040. Measured all the wall thicknesses with calipers and a digital vernier in at least 3 places. I don't have ultrasonic measuring kit to hand!
They range from .161" to .212" on the thrust walls so I am happy with that. They are a little thinner on the front and rear (pin sides) but not enough to worry about. So I can now start getting the parts together for the short block. I basically need a set of splayed caps, rods and pistons along with a cam kit to have the block finished off. Got everything else I need.
Old 07-18-2014, 03:17:44 PM   #500
flak monkey
Decided that the T3 exhaust side was too small and that I needed something bigger. Moved on the hybrid turbos and wastegates and ordered some different bits. So lots of goodies arrived today! Fast shipping from SS Autochrome - from California to UK in 4 days. Wasn't expecting the best quality items, as I know turbos at this price can only be made in China but knowing that I'm impressed with the quality of the parts, packaging and service so far.
They came packaged as a pair
These are the anti surge turbos with journal bearings. The compressor and turbine sizes are exactly as advertised - checked with a vernier. They are water cooled centre sections - not sure if I'll connect up a water supply to them or not - any reasons why it's needed? All of the bolts holding the housings to the centre section are stainless too. There's some radial play in the shafts, but no more than I'd expect.
These are *exactly* the same turbos as sold by CX Racing - the part number on the boxes was TRB-GT35-2-P82, and the hot side has WSR Turbo cast into the housing
Next the 50mm BOV - packed in foam, 2 different springs ship with it along with a load of other accessories and a mounting flange with v-band. Also comes with a spare seal for the plunger. I've fitted the lowest pressure spring for the time being. The diaphragm is very thick heavy duty and nomex reinforced.
Final goodies was a pair of 60mm wastegates. These have 4 springs with them for different boost levels from around 8 psi to something beyond silly and everything in between. Also have adjustable preload on the spring at the top. I'll be running electronic boost control through my ECU so I fitted the softest spring and bench tested with my compressor. They start to open at 8psi and fully open at 12 psi. I also have over boost protection on my ECU, so I'll be using that as a final safety device.
Again the diaphragm in these is heavy duty and nomex reinforced...
I need to pick up a couple of scrap heads for mock up then I can get on with some fabrication on the headers.
Old 07-22-2014, 04:31:33 PM   #501
flak monkey
Picked up a junk cylinder head tonight to use for mock up and ordered some stainless tube to modify the headers. Quite a bit of modification to do, including some braces to support the weight of the turbos and prevent the headers cracking.... all will become clear!
Old 07-23-2014, 03:51:56 PM   #502
flak monkey
Now I've got a head for mock up its clear that they are going to hit the front of the upper control arm, even with the rough measurements I have taken. So it leaves me with 2 options, cut these apart and completely re-make them, or buy some different ones which will fit. The collector needs to be a good 6" higher than it is.
The plan is to make a mock up support bracket for the turbo and then make the headers to suit. Stainless mandrel bends work out to be about £15/$24 each. In addition to cutting up what I have I think I'd need to make something to work:
4x 90 deg
2x 45 deg
2 x 180 deg
Old 08-02-2014, 01:24:41 PM   #503
flak monkey
Made a start on header mock up today.
First things first, make sure the turbo will fit under the hood without too much adjustment of existing parts of the car! What I wanted to work out was where the outlet of the collector will need to be from the header. So I cut up my existing headers into their component parts and tack welded the turbo flange to one of the 3" 90 deg bits of tube and bolted a piece of 1/4" plate to the front of the head.
After a few hours messing around I think I have something that will work. Got about 1/2" clearance to the underside of the hood. Only thing I am slightly unsure of is the turbo has ended up being mounted at a slight downward angle to the front of the car. Around 3 degrees.
A little modification will be needed to the inner fender, but nothing that a hammer and dolly can't sort out pretty quickly.
Old 08-18-2014, 01:53:38 PM   #504
flak monkey
Finally got around to putting some badges back on the car, and fitting some new parking lamps. Picked them up from Classic Industries while on vacation in the USA.
Work on the turbo headers continues, I've ordered the additional bends I require and I'm just waiting for those to arrive. The piece of plate is there only for location purposes. Once I've got the header tubes made I'll be welding the collector to the turbo flange tube directly.
Old 08-18-2014, 02:14:14 PM   #505
1971SS
badges look good!
My build thread... http://www.nastyz28.com/forum/showthread.php?t=277041
just because you can tell me the physical properties of your shoe laces doesn't mean you have the common sense to tie them...
1971SS is online now   Reply With Quote
Old 10-12-2014, 01:41:10 PM   #506
flak monkey
Right, winters here, the tax has run out so time to get cracking.
The 700r4 is out and gone off to a new home - so made a proper start on the 4L80. Bought it in bits, the only thing I knew about it was there was no drive in most gears. Clean down the case and rebuilt the gear train, fitted a new rear band, new output shaft seal and a few other bits and dropped it into the case then set about rebuilding the clutch packs and drums.
All looked good - could still see the writing on the OD and direct clutches. Not so good when it came to the forward clutch though....
No friction material left at all and the bevel/spring plate was flat!
Soon became apparent that whoever did the last rebuild didn't do a very good job... these are the seals from the apply piston
Needless to say they weren't going to be doing much at all.
Just waiting to pick up the rest of the rebuild parts next weekend then I can finally get this transmission rebuilt and start thinking about trying to fit it in the car.
The plan for the winter is to get this transmission built and fitted behind the current engine which will give it a good road test. And in the mean time start making the headers for the turbos and building up the new short block with a view to having the twin turbo set up ready to fit toward the end of next year with enough time for some testing before winter 2015.
Old 10-26-2014, 04:33:30 PM   #507
flak monkey
Been working away on a few bits and pieces. Finished building the 4L80 after the rest of the parts arrived from the USA last week. Was waiting on the billet input shaft and clutch hub. There's a significant difference between the original input shaft and the billet one, no undercuts at the splines and seals
Shouldn't break that in a hurry! Just waiting for a torque converter so I can get it back in the car - then I'll need to make a cross member for it amongst a few other bits. It's not the prettiest, but it's whats inside that counts
Also made a start on the block. It's a '90 2 bolt main block out of a day van. Nothing special about it really. Checked the cylinder wall thicknesses and they are all good - no core shift at all. Its been bored .040 recently so a quick hone of the bores will sort that. Obviously a 2 bolt block isn't going to stand up to the turbo power very well.
First step in fixing that is a set of Milodon splayed main caps. Measured them up and milled the pads on the caps to suit the registers in the block. Fitted them back on and drilled and tapped the outer bolt holes. It's now ready for line boring.
Next thing is a thorough clean out and then a half block fill - need to get a couple of bottles of acid to give the water jackets a soak before filling it. I'll get the block line bored after its been filled. A job for another day.
Old 11-16-2014, 01:54:12 PM   #508
flak monkey
Made a start on cleaning up the engine bay and making room for those turbos. First job on the list was making a pair of tanks to replace the washer bottle and expansion tank.
So I got some 2" stainless tube and knocked up 2 of these things
Turned up some aluminium caps for the filler necks and fitted them in the space between the core support and the radiator. They don't hold a lot of fluid (about 1 litre each) but its more than enough for the purpose
Old 12-14-2014, 12:11:21 PM   #509
flak monkey
Kind of messing around with various parts on the car - ultimately all modifications for when the turbos are fitted. While the original engine is still fitted it makes an ideal mock up and test bed for brackets etc.
I needed to clear some more space at the top of the engine bay to allow for routing of lots of hoses etc so I decided to go with an electric water pump then move the alternator low down on the block. I've also got a power steering pump off a 5th gen camaro (type with the remote reservoir) to make some brackets for.
I'm going to use the current fuel pump feed to power the water pump as I'll be replacing the pump feed to cope with 2 pumps later on anyway.
Today I've got the alternator mounted up in a place I am happy with. I'm making a double poly vee crank pulley with a trigger wheel as well (alternator and PS pump will run off seperate belts), I just need a lump of 7" diameter aluminium...
Need to also hook up the bottom rad hose, which will route between the alternator and the bracket neatly out of the way.
Copyright © 1997 - 2014 NastyZ28.com Inc.
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
