Old 04-23-2012, 10:45:46 PM   #1
tms71z28
Smog tube pipe inserts
Has anyone removed the original smog tube from the exhaust manifold from a 1970-71 Z28?
Do you know the length of the pipe insert?
The GM pipe insert is 3 1/8" long.
Years ago I had an auto shop Install my original exhaust manifolds and the smog tubes. I supplied the GM pipes for the tubes. When I removed the smog tubes and the pipes recently they were less than 2” long. I’m not sure if the auto shop cut them down or something else changed the length.
Any information would be greatly appreciated.
tms71z28 is offline   Reply With Quote
Old 04-23-2012, 10:58:07 PM   #2
mgoad1971
mgoad1971's Avatar
Assuming this is a 1980-81 Camaro California car???
Just because It's in the news all the time, doesn't mean it's happening all the time!!
Camaro Diagrams
GM Part# Lookup
Fuel Types FAQ
Why swapping MTBE to Ethanol in gas is stupid...
mgoad1971 is offline   Reply With Quote
Old 04-23-2012, 11:02:09 PM   #3
twozs
why , his name is tms 71Z28 and his profile seems to verify that .
twozs is online now   Reply With Quote
Old 04-23-2012, 11:14:53 PM   #4
mgoad1971
mgoad1971's Avatar
I don't judge a book by its cover .
Smog tubes are different for BBC than SBC. I was just reaching for more info.
Camaro Diagrams
GM Part# Lookup
Fuel Types FAQ
Old 04-24-2012, 01:19:21 AM   #5
Bob R
Bob R's Avatar
Ran into this problem years ago. The Smog Tube inserts (the ones that go into the exhaust manifold). The replacements from GM are slightly longer than the originals. Not sure of the exact length at the moment. However if you use the current replacements (assuming they are still available and have not checked) will rub up against the exhaust valve stem. So what you have to do is just grind them down a bit. I honestly cannot remember how much I had to take off since it was years ago. It wasn't a whole lot but you definitely do not want it rubbing up against the valve. Not good.
Bob R is offline   Reply With Quote
Old 04-24-2012, 08:16:08 AM   #6
COPO's Avatar
I'll measure mine. When GM still had them before selling them all off to a US Co, I purchased one since they were $12. ea. I just cleaned them and reused mine.
The new one was the same as my originals from my 70.
Mark
70 Z28, M22, 3.73 - Lunati 20120121 Retrofit Roller Cam
http://www.nastyz28.com/~copo/index.htm
Prev Z/28's
1968 Z/28
1971 Z28 4-pd
Z28's I ordered new:
1977 Z28 4-spd w A/C
1978 Z28 4-spd
1980 Z28 4-spd
COPO is online now   Reply With Quote
Old 04-24-2012, 12:26:31 PM   #7
70COPO
I had to shave mine back a bit also. Perhaps the cast depth of the insert hole on the manifold could have some casting variation?
70COPO is offline   Reply With Quote
Old 04-24-2012, 06:50:55 PM   #8
Bob R
Bob R's Avatar
I just measured an original from a 1973 Z28. It is 2.691 long. Anything longer than this will contact the exhaust valve stem.
Old 04-24-2012, 11:37:47 PM   #9
Smokey34
Not sure if this will help or add confusion, but I took a pic and measured one that I got from Bill Hodell for a 1970 BBC. They are almost exactly 2-1/2" long.
BBC smog inserts from Bill Hodell
1970 SS/396
1991 Z28/5.7
1999 Z28
Smokey34 is offline   Reply With Quote
Old 04-25-2012, 08:11:48 PM   #10
DCL70
DCL70's Avatar
The smog tube shown in the photo below is from a 1972 LH exhaust manifold cast # "3989041" dated "F 23 72" (June 23 1972).
The tube measures 2.68" long with a diameter of 0.32".
Dave
Originally from "Narragansett No. 6" in the Bay State
1970 Camaro SS350 w/Muncie
(real long term project, 1990 to ????)
1966 Corvette 327 w/Muncie (1980 to 1995 restoration)
1994 Camaro Z28 w/6-speed M.T.
DCL70 is offline   Reply With Quote
