Go Back   NastyZ28.com > Body & Chassis Restoration > Electrical Systems
Old 04-14-2012, 12:23:02 PM   #1
split70cam
LED light on 1970 to 81 dash
Anyone install LED bulbs on 70 to 81 dash? I bought LED light and put them in with the correct poalrity offcoures but they do not work. The one light at the end of the circuit bord lights up and one is dim the rest are dead. They all work when connected individually to the power source. Is there some kind of electrical explaination to this? I know LED lights are tricky. Anty suggestions please. Thanks
split70cam is offline   Reply With Quote
Old 04-14-2012, 12:34:53 PM   #2
vfw_1168
vfw_1168's Avatar
You try the strip lights
brian "shipwreck" shepherd
sold 81 camaro Z28 350 with 4 bolt main. Summit Carb, Borg warnner 4 speed. 100% Z28 mustang killer...my Z is on custom grills on fbodywarehouse
Originally Posted by BondoSpecial
I'm okay with not having bumpy nuts, no one is looking down there anyway.
http://s1216.photobucket.com/albums/dd379/vfw_1168/
vfw_1168 is offline   Reply With Quote
Old 04-14-2012, 12:51:27 PM   #3
split70cam
no strip light. I just got the replacement bulbs, they look like the original but instead of filiment they have five little LEDs
Old 04-14-2012, 12:56:48 PM   #4
Twisted_Metal's Avatar
Clean the contacts on the bulb holders with a tiny file.
The ones inside the holder and the contacts which touch the printed circuit panel.
I test the LEDs in the cluster with a 12V trickle charger before I install the cluster in the dash. It makes this job easier.
Good luck!
Old 04-14-2012, 05:41:00 PM   #5
split70cam
I did what you sayed and filed the plugs. and you are right. I tested the metal on the little plastic plugs they are not conducting electricity. I'm going to replace them. thank you.
Old 04-14-2012, 07:06:03 PM   #6
Some of the LED bulbs don't have the wire contacts positioned very well either.
I found I had to "tweak" them a bit for them to line up properly with the contacts inside the holders.
Old 04-14-2012, 10:46:15 PM   #7
Z28 Mark
Good luck!
Try an eraser for a “typewriter” (white- slightly aggressive eraser) as it might be a little easier to clean up- This is how we were taught to clean PC board fingers (gold contacts) in Tech School.
Mark (A.K.A. Z28 Mark)
Camaros Limited~Nor Cal
1973 Camaro Z/28
2001 Camaro Z/28
Z28 Mark is offline   Reply With Quote
