Old 03-05-2010, 04:18:07 AM   #16
gramps
yeah i do have 400 short block, block is cracked but crank is a-ok. have a set of flat top hyperectics aswell. iron eagle heads also on the shelf. but those pieces are for a different project, the point of this exercise is to create a 350hp powerplant from 350s that i have collected (short of cam and machining the heads to accept bigger cam)
that being said that was a good link to the rear main adapter on ebay, thanks.
i would prefer to use a newer block just for the fact of a roller cam, should use less lift/dur to attain the same power level, but flat tappet doesnt bother me any, just need to run additive's. was thinking for cam size something around .480 lift with .220 duration at least i think thats getting close to maxing out the vortec's without a bunch of machining and watnot.
gramps is offline   Reply With Quote
Old 03-05-2010, 07:27:54 PM   #17
bigblock665
Send a message via AIM to bigblock665
Originally Posted by Louich
good luck stuffing that crank in the 350 block without machining it
Yeah its gotta be machined, thats the only downfall. Some shops will also charge you an arm and a leg to do it.
With that said, the simple route to take is take the 350 and put in a mild cam, flat/dome to pistons and a nice set of heads and you got a potent 350. Cams and heads will make or brake and engine.
***Bullets and octane***
My MONEY PIT!>
http://i880.photobucket.com/albums/a...12091607-1.jpg
bigblock665 is offline   Reply With Quote
Old 03-05-2010, 07:29:14 PM   #18
bigblock665
Originally Posted by ZS10
I doubt that's ever done anymore. New cranks are cheaper than trying to machine a junkyard 400 crank.
The 383 crank kits are a good buy so junkyard crawling is no longer needed.
My MONEY PIT!>
Old 03-05-2010, 07:44:05 PM   #19
Louich
all depends on what the person or customer wants to do....now if i have a customer tell me what he wants and this is his budget i can't go throwing afr heads and all forged internals into a dart block and hand him the bill...
read post number 1 again.... and again and again....
9.54 in the 1320 with stock 10 bolt with 342's
Louich is offline   Reply With Quote
Old 03-05-2010, 07:46:06 PM   #20
bigblock665
"see if i can build a 350-400hp 350 out of the stock components (except for cam" Now i feel stupid...
My MONEY PIT!>
Old 03-05-2010, 07:54:53 PM   #21
sweetsoul
if you were not so far away i would swap you a lightweight latemodel flywheel for a driveshaft....
sweetsoul is offline   Reply With Quote
Old 03-07-2010, 03:22:31 AM   #22
hhott71
hhott71's Avatar
use the98 vortec engine and flat top p;istons
get reground roller cam.
That will see you in the 400+ range
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
Originally Posted by Lowend
For the record I agree with Aces and hhott71
If the rear end grenades it blows your nuts off...
Originally Posted by Strange81Z
That's because we have more to give....ask any women who's been with a conservative and a liberal! LOL!
hhott71 is offline   Reply With Quote
Old 03-07-2010, 05:26:54 AM   #23
sooner
sooner's Avatar
^agree. here is a link to a place that will sell you a lt4 hot cam or xe282hr regrind for $120:
http://www.willhoitescams.com
dm44
Originally Posted by theflash
Its a good site, but I'm not going to cream my pants over it.
sooner is online now   Reply With Quote
Old 03-07-2010, 09:40:01 AM   #24
77wolf10.85
hey thanks for the Okie link, fellow Okie. I have been wanting to keep some of my money at home vs supporting UPS and Fedex.
Cams Inc was the last I knew of in Okla, and they went to all industrial a long time ago. I fetched a 399(V-16 Cat) camshaft from them here 10 yrs ago or so, and asked them if they still did hotrod stuff and they said hell no, no money in it.
That Willhoites would be down on the river right off I-40, I'll drop in on them some day. See if they grind here or bring it in from Dallas. I have it in my head I went to HS with a Willhoite. A Randall Willhoite. And I want to remember a hotrod associated with that name, but Lord that was a lot of people ago.
Tim
"WOLF™" is my car
421"³
77wolf10.85 is offline   Reply With Quote
Old 03-07-2010, 02:14:08 PM   #25
sooner
sooner's Avatar
Yeah, actually I stumbled on to willhoites while searching an import message board trying to find some info for a friend. I got the same story you did from cams inc. when I called them about a year ago. maybe they can help me out when I decide on building a pro street earth mover.
If I go ahead with the 383 build I have been threatening to do, im defiantly gonna try their xr282hr knock off.
dm44
