Old 01-14-2010, 05:53:51 PM   #1
earnhardtgm3
Fuel Pump
What is the best fuel pump for SBC?Was thinking maybe a holley or edelbrock mechincal pump.Need your input.Thanks..Any model numbers would be helpful.Thanks...
350 bored .030 over
Trick Flow 64cc aluminum heads
flat top pistons
Holley 300-36 intake
holley street avenger 770 carb
camshaft is a lunati voodoo 60103LK
Advertised Duration (Int/Exh): 268/276
* Duration @ .050 (Int/Exh): 227/233
* Gross Valve Lift (Int/Exh): .489/.504
* LSA/ICL: 110/106
* Valve Lash (Int/Exh): Hyd/Hyd
* RPM Range: 1800-6200
jegs 2400-2700 stall converter for a turbo 350
3:42 posi rear
1979 Z 2/8 Bought new----1971 LT 1 350,3:42 posi,T-Top http://i264.photobucket.com/albums/i...2811Medium.jpg
My 79 Camaro Z28 progress and paint:
http://www.nastyz28.com/forum/showthread.php?t=129623
earnhardtgm3 is online now   Reply With Quote
Old 01-14-2010, 06:34:33 PM   #2
1977_TPI_Camaro
1977_TPI_Camaro's Avatar
I don't know about "best" but I'm running a carter mechanical with a nearly identical cam to that, with a 750 edelbrock. Not sure the model #, its the regular carter street pump w/ the rebuildable diaphragm thats been around forever
Steven H., Charles Cty, MD
1979 Z28 project thread, 10:1 350, World Sportsman II heads, XM276HR roller cam, 700R4, PATC Raptor 5X converter, Hotchkis front springs and Bilstein/Hotchkis shocks front and rear
1980 Firebird project thread, 76 Formula hood/nose/bumpers, 350 chevy, 4 speed saginaw
1977_TPI_Camaro is online now   Reply With Quote
Old 01-14-2010, 08:07:46 PM   #3
z2879camaro
I'm running a holly blue fuel pump haven't had any problems some people complain about the humm but I like it cuz it let's me know if it's on and working
z2879camaro is offline   Reply With Quote
Old 01-14-2010, 08:27:35 PM   #4
CorkyE
CorkyE's Avatar
Unless you're planning on the giggle juice, a good mechanical such as the Carter will work just fine.
Corky
79 Z28 bought new, honeymoon ride same year, same wife, same car.
CorkyE is online now   Reply With Quote
Old 01-14-2010, 09:54:54 PM   #5
Gary S
The cheap Carter pumps are hard to beat. Often you can spend much more only to find out that the fancy ones tend to leak and need repairs. The cheap throw-away Carters tend to run about 100K miles and then you throw them away and $15 gets you another new one.
Gary S is offline   Reply With Quote
Old 01-14-2010, 10:23:24 PM   #6
Send a message via MSN to muscl car Send a message via Yahoo to muscl car
i'm running a mech carter "strip" pump with 10 psi unregulated pressure and easily supports my t/ram with dual 660's .i also have but not mounted yet is a holley "blue" electric pump which will get installed soon
old school / day2
engine
my camaro
open headers
thru the mufflers
Old 01-15-2010, 09:11:55 AM   #7
warped
Another vote for carter here. I use the M6900 on a couple of different motors and wouldn't trust anything else. Unfortunately, I believe Carter has discontinued that model, don't know if another model is similar. personally, I have never had good luck with Holley mechanical pumps. good luck.
Pat
I feel like I am in the "Planet of the Apes" and the apes are in charge. Have another banana, Barry!
warped is offline   Reply With Quote
Old 01-15-2010, 09:18:05 AM   #8
Big Mouse
I started off with an inexpensive carter when I was running my qjet. It worked great! This was on my 383 - which is very similar to yours with a slightly larger cam.
I then thought I had to upgrade when I went with my Holley 4150. I first tried a Holley 110 gph pump (I sent it back due to inconsistent fuel pressure).
I currently have an Edelbrock Vic Jr pump (130 gph). It works great with my return-style regulator. It's probably overkill, but I have no complaints.
Eric
1980 Z28, t-tops, 383, TKO600, 3.73's http://www.cardomain.com/ride/2373747
Big Mouse is offline   Reply With Quote
Old 01-15-2010, 08:23:53 PM   #9
earnhardtgm3
Looking at this one:
http://www.summitracing.com/parts/CRT-M4891/
and this one any good?
http://www.summitracing.com/parts/EDL-1721/
Old 01-16-2010, 06:53:14 PM   #10
Tokyo Torquer3
Carter 172 or Holley 130 or 170gph mechanical pump will be more than you ever need with that engine. You could actually do fine with a 110gph pump, but the others dont cost that much more and you will never have to wonder if it is enough.
1973 RS Z28: 401ci Dart Little M, Littlefield 6-71 supercharger @14lbs boost, Callies Magnum crankshaft, Lunati Pro-Mod rods, JE pistons, 7.8:1 compression, AFR 227 Comp heads, T&D 1.6 shaft rockers. Reed solid FT cam (240/250@.050, .523/.542 lift, 112 LSA), QFT 750 carbs, Lemons headers, Mezier mechanical water pump, Tremec TKO-500 5-speed, Moser 12 bolt, 33 spline axles & 3.42 gears.
Tokyo Torquer3 is offline   Reply With Quote
Old 01-20-2010, 05:52:59 PM   #11
earnhardtgm3
Any thoughts on this one;
http://www.summitracing.com/search/P.../?autoview=SKU
Old 01-20-2010, 06:51:03 PM   #12
badazz81z28
Originally Posted by earnhardtgm3
How come "Camaro" is not under application??
Slowly but surely it will get done........
badazz81z28 is offline   Reply With Quote
Old 01-21-2010, 08:37:23 AM   #13
Big Mouse
That one looks just about right. I have the big brother to that one which requires a regulator. I'm happy with mine. It looks like you can index the base to get the fuel lines where you need them. Good price, too!
Actually, I think it is: http://www.summitracing.com/parts/SU...Model%7cCAMARO
Eric
