06-14-2009, 08:55:40 PM
Mr. A, Lifetime Coffee Barista
Knock
Guys, I need some troubleshooting help. As most of you know, I don't know jack about engine work (yet)...I have a knock somewhere in the valvetrain (a guess), I have the driver side valve cover off, but don't know what to check, or where to start. I would really prefer not to start the engine with the cover off...but if I have to lol, I guess I'll clean up oil...thanks guys!!
Jim
71 Camaro RS
73 AMX
77 Trans Am
Carlisle 2011 DUIT, Yea Cmon BAB(Z)!
I plumb for food, go fast parts, guns and ammo
Unable to join the banned click!
06-14-2009, 09:01:54 PM
go to speed shop and get the clips for the rockers that block the oil holes, that way you can do what you need to do, just dont run them for very long periods of time like that.
06-14-2009, 10:30:53 PM
what do you consider a long period of time?? j/c
is it ok to use those clips during adjustments?
Camaro-less yet again.
But I did get me a '66 Chevelle
06-14-2009, 10:38:35 PM
yes they use them for adjust the rockers with the engine running. i wouldnt let them run for more than 10 or 15 min, anyone else ??
06-14-2009, 11:14:48 PM
Old valve covers with the tops cut out. 1000% better than the deflector clips. Hose or long screwdriver held to the ear with the other touching engine. Track down the location of your noise.
06-15-2009, 12:42:46 AM
Jim, with the valve cover off, grab each rocker and see if any are real loose. You will have to rotate the engine a few times because 2-3 rockers will be in the open valve position and will be tight. But if any can be moved sideways more than a 1/4 inch this may be whats causing the noise although most valve train noises are ticks, knocks are usually crank/rod problems. Check you pm's.
Can I join the GFB Fan Club?
Originally Posted by BonzoHansen
You are cruising for a banning! LOL
06-15-2009, 08:26:41 AM
Thanks Mike, I'll give you a shout this evening if I get home early enough.
Jim
71 Camaro RS
73 AMX
77 Trans Am
06-15-2009, 09:47:15 AM
Could timing advanced too far cause the knock??
Jim
71 Camaro RS
73 AMX
77 Trans Am
06-15-2009, 10:28:48 AM
That could cause it to knock, I have a guy here at work that just droped a BB in his chevell and it had a knock to it. Come to find out he had 36degs int. timming set.
Robert
73 Formula
Search this Thread |
Rate This Thread |
