Old 05-26-2009, 03:19:25 PM   #1
leesr
SBC 400 flywheel
heres the deal, I have a std 168 T flywheel that was drilled & converted to a
383 stroker external balance by a previous owner.
I was replacing my clutch, Took my flywheel & pressure plate to have it balanced at a machine shop. and they FBAR my flywheel.
shop said it was out 76 grams, they added heavy metal now it's out of balanced. vibrates like hell. Never asked me for permission to do this.
I would like to know what the unbalanced weight is for a standard flywheel & a matching damper for a 383 stroker crankshaft externally balanced .
My crankshaft is of two piece seal design. I will be dropping the oil pan to see the crank serial# & make sure it's not internally balanced.
leesr is offline   Reply With Quote
Old 05-26-2009, 03:46:08 PM   #2
RacerRick
I hope you mean a 2 piece rear main seal and not a 2 piece crankshaft!
1952 Chevy 1/2 ton short box
1955 Chevy 150 Handyman - 2 x 62-1, 406, TH400, 8.5"
1967 Camaro - 230ci/Super T10 (for now - darkside coming)
RacerRick is offline   Reply With Quote
Old 05-26-2009, 06:08:05 PM   #3
leesr
Yep thanks corrected my mistake.
have I hit a dead end here?
I was hoping some one has run into this before.
Part of my problem is if I purchase a new fly wheel I have to also buy a new clutch.
the stock SBC 400 External Balanced flywheel takes 11" clutch.
my retrofit flywheel had a 10.5" clutch
Old 05-26-2009, 08:30:32 PM   #4
1972L
McLeod had some on Ebay for $200
They were Aluminum
They were factory closeouts
and dual drilled for both clutch sizes
I think the factory SBC external balance weight is 44 grams on a 400
1972L is online now   Reply With Quote
Old 05-30-2009, 02:31:27 AM   #5
leesr
smb 400 flywheel
an other balancing shop put an external weight on a scale.
I was told "125 Grams"
found a Mcleod brochure
125.5 grams is for 1986-97 GM 1 piece seal Crank SBC 305 350
156.1 grams is for 1970-1981 GM 2 piece Seal Crank SBC 400 383
210.5 grams is for 1970-90 GM Cranks 454
Go fiqure
Old 06-03-2009, 02:57:54 PM   #6
leesr
see above comments
Old 06-03-2009, 06:29:43 PM   #7
1972L
Mcleod has the "bolt on" external weights on some of their flywheels
I guess they would know better than anyone
Old 06-03-2009, 11:23:15 PM   #8
pdq67
BANNED
Please consider looking into what Northern Auto Parts sell's in the way of flywheels and flex plates.
pdq67
pdq67 is offline   Reply With Quote
