Old 06-04-2008, 02:01:09 PM   #1
Solid71Steel
ok to sandblast intake manifold?
ok so i have two stock intakes in my garage that have accumulated alot of surface rust out and inside of it and i was wondering if these parts are able to be sandblasted? i ask b/c i've heard alot of engine components should not be sandblasted, does this apply to the intake? i mean i know i'd have to re-file the flat contact surfaces but is it safe aside from that?
Solid71Steel is offline   Reply With Quote
Old 06-04-2008, 02:19:55 PM   #2
79camaro2001
79camaro2001's Avatar
I have done intakes before, and had no problems from them. I just don't focus the blast at gasket surfaces. inside and out.
Check out my camaro
1979 Camaro picture site
79camaro2001 is offline   Reply With Quote
Old 06-04-2008, 03:17:03 PM   #3
Kamikaze
Kamikaze's Avatar
Sand, bead, glass, media blasting is perfectly fine!
Like 79camaro2001 stated, be careful around the gasket surface areas!
Just be sure to completely and throughly wash and scrub it out before installing it.
Vehicles were made to be driven! Classic is cool but stock is boring!
Kamikaze is offline   Reply With Quote
Old 06-04-2008, 03:18:24 PM   #4
Chevrolaine
Chevrolaine's Avatar
Duit
"I'd agree with you, but then we'd both be wrong"
Laine O LIVE LOVE DRIVE!
72 Camaro - 468,3;42, Woot!
2015 Nasty Z28 Calendar Cover Car
10 Camaro 2SS/RS - Modern day fun!
Chevrolaine is online now   Reply With Quote
Old 06-04-2008, 03:18:27 PM   #5
green 1977
green 1977's Avatar
Yup did my intake... no problems what so ever
Jim Stokkeland: I don't call it plumbers crack g...I call it my resume'
67lemanster: i feel for that member(oh does that sound bad)
protour73: man.....do you all have your collective doofus hats on? DOH!!!
And remember only two defining forces have ever offered to die for you, JESUS CHRIST and the AMERICAN SOLIDER. One died for your soul, the other for your freedom.
green 1977 is offline   Reply With Quote
Old 06-04-2008, 03:32:36 PM   #6
More2Life
More2Life's Avatar
I sand blasted an Edelbrock one on my old 350 and then clear coated it. Turned out pretty good, easier to keep clean too.
-Chaz
More2Life is offline   Reply With Quote
Old 06-04-2008, 06:22:49 PM   #7
mrdragster1970
mrdragster1970's Avatar
Location: Chicago, Illinois..... Far S.W. Subs, RT 66 Area
I usually use media blast material. My buddy has his cabinet set up for pistons. My cabinet has sand, so we share.
I did 4-5 in his, came out excellent. Sand can be a little rough, especially as said, on gasket surface.
Founding member of the Cloudyside. US Navy veteran, and damn proud of it!!
PARTS FOR SALE
'94 Pro-Modified Lumina. Photo's of fast car Photos & License 6.54 @ 213 mph 1.00 60'
'70 1/2 RS, 8.57 @ 159 1.29 60'
'72 plain jane, getting chrome moly chassis
For my babies, never forgotten
mrdragster1970 is offline   Reply With Quote
Old 06-04-2008, 07:24:44 PM   #8
pdq67
BANNED
Remember to pull the crossover heat shield and drive screws off if you are doing a stock intake that still has this on it so that the grit doesn't get caught behind it b/c if you don't, the blast media can later come loose and trash your engine!!
pdq67
PS., carefully remove the drive screws and then carefully pein their holes a schosh tighter/closed if you will w/ a small ball-pein hammer and a drift punch and reuse them unless you can find new ones.
pdq67 is offline   Reply With Quote
Old 06-04-2008, 11:46:59 PM   #9
Damon
And clean the heck out of it after blasting- sand/media can hide out in many places. You don't want it finding it's way into your engine.
Sand blasting is too harsh for aluminum intakes, in my opinion (I don't know what media might be appropriate for aluminum, but I'm sure there's something appropriate). On cast iron intakes sand blasting is fine (avoiding gasket surfaces, of course). Aluminum intakes I usually get put in a big industrial "washing machine" that many engine shops in my area use for parts clean up. They come out looking "holy cow!" better.
1990 454SS pickup. Sold, but I think she found herself a good home.
78 Malibu. Inherited with only 35K on the odo! Mild 383 with Weiand 142 blower on top. Mid-high 12s on street rubber, bottom 12s on DRs with the trans left to shift for itself. Runs so good I may never drive it again.
"Last remaining QJet tuner on planet Earth!"
Damon is online now   Reply With Quote
Old 06-04-2008, 11:49:53 PM   #10
Cougar125
Cougar125's Avatar
Glass blasting works excellent. I did the intake for my truck (still not installed) on it and it looks fine. Make sure to blow it out real good with a compressor.
Ev
Trust me...you don't have to see it to be able to use it. - cam80
I've been trying to get the hummers in my yard, but no luck. - spoonLT1355
Levi, I can understand.....buzzers would be annoying on a car with tube doors - John Wright
ugly chicks need lovin too - Lammy
NW Lifetime Member of GFB Fan Club.
Cougar125 is offline   Reply With Quote
Old 06-05-2008, 12:56:13 AM   #11
li0nhart123
You can use baking soda on alumunim to not damage it as much....i ahve seen aluminum down with sand...makes em turn a grey color...i don't beleive it hurts it any though.
li0nhart123 is offline   Reply With Quote
Old 06-05-2008, 09:58:59 AM   #12
tom3
One grain of sand in a cylinder and it's all over. I'd never do it myself. Aluminum intake? Clean it real good with kerosene, maybe some aluminum wheel cleaner or a weak acid solution to whiten it up some. I've used battery acid before with good results. Clear coat darkens it some but keeps it looking better longer.
tom3 is offline   Reply With Quote
Old 06-05-2008, 01:42:57 PM   #13
Twisted_Metal's Avatar
I hit my Weiand aluminum intake with oven cleaner to clean/degrease it.
Painted with "aluminum" rattle can paint and cleared it.
It stays quite clean this way but the paint/clear will not withstand a gas spill.
