Centrifical superchargers?
I am looking to replace my roots blower with a centrifical Supercharger. Does anybody know where I can get a really good deal on a procharger or Vortech that is capable of 1200hp. It will be for a SBC motor. Any help would be greatly appreciated.
Thank you Michael |
yes I was looking into an f1-x or the F2. I also need to figure out how Im going to mount it... Of course this all depends on the cost of the unit and kit as well. I think I am going to start with a max hp of about 900hp but would like to be able to increase boost and power as I get bored or used to that power level.
Michael |
If you want all brand new, I just spent a lot of money at ProCharger. I will ask my contact if he can help you out. I'm a new customer, and this guy is not really a salesman, he's more of a Pro-Mod type representative it sounds like, so I don't want to say something I shouldn't?? If you're trying to do this cheaper, there is a ton of stuff on junk. I mean a ton!! Just look through for your model and engine type & you might get lucky?? Or find as much as you can used, and order the rest new?? Let me know, I'm in the middle of a huge build, so I talk to him regularly. Oh yea, have you gone to their site and looked at the power chart. A F-2 can make more then listed, ~2000 HP, so make sure you pick the model you really need. I didn't even buy the biggest, and I'm looking to run 6 seconds at 205+ mph. I was told by several very experienced racers, their charts are definitely below max power possible?? An F-1 will make 1200 HP easily. Good luck. . |
You sir should track down member camcojb
Jody has done quite a few mega-power Pro-Charger setups and can certainly point you in the right direction |
Thanks Brett. My stuff has been pump gas street deals. I do agree, the Prochargers can make more than they claim. At the time I did my big block 69 Camaro they did not have the F series yet. I ended up using a D1SC which was a bit small but I wanted that size to fit under the stock hood easier. Still made over 1000 HP on 91 octane and 14-15 psi of boost.
I bought my first kit directly from Procharger, but then found Scott at SDCE and bought all future setups from him. He has a tensioner that's much better than the Procharger unit. When many guys were having problems with belt slippage I was only running an 8 rib setup that held 15 psi without issues (again, needed the smaller belt for clearance, it's tight with a big block). He does a LOT of Procharged cars for track and street. I'd at least call him to pick his brain for a recommendation. Make sure to set aside some time, he likes to talk. ;) http://www.sd-concepts.com/ The F1 will support 1100+ HP. It's also only 9" diameter which fits easier in our cars than the larger models. I've heard of guys well over 1200 HP with that blower. |
Steve Morris is the Pro Charger guru around here. His shop is in sight of my house. Google his Boostmaster buick wagon
I just talked to Steve about getting a custom cam. He does some stuff a little different for us alcohol guys. Now I have heard from a few guys he likes to fluff his numbers a little, and is very proud of his prices?? Damn Jody, you took a 900 HP rated blower and made 1000+ with cheap gas. Just imagine some real fuel and a pulley change!! That's frigging amazing, another another reason why I switched myself. The future is boost & E-85/alcohol, for track & hot rodders. 1000 HP will be the normal combo for cars that can be driven anywhere!! Especially in E-85 areas, it would be silly not to use it's higher octane, and cooling properties. I'm actually going to run mine with no water, and let the alcohol keep it cool. . |
Have you learned anything that would help on something like I'm building?? Any tips for a 1700-2000 HP combo or does everything change at a certain power level. I ask 10 guys the same ?? and I get 8 different answers?? Nobody agrees on ignition. Nobody agrees on injection. Nobody agrees on blower rpm. Nobody agrees on engine rpm. ETC ETC. . |
I gotta share... Jody's old car, just because I love it
![]() ![]() Chassis Dyno: ![]() |
Torque monster!! . |
Already bought a big beautiful F-3R. I bracket race, so I have to hit the dial in, and I hear it's much easier to do with a belt. It does happen, but very few turbo's have ever won in my class. What makes a blower maintenance harder?? I kind of thought they would be exactly the same?? I know anything that spins at 70,000 rpm will need to be watched, but don't turbo's spin high also?? I'm probably going with a 3.70 gear, which at 205 mph puts me at 7600 rpm. Which is less then my nitrous engine at much lower speeds. Also can't you change pulley's to set up boost levels needed per event/application?? It can't be that hard, but obviously not as easy as typing in a file name?? Thanks for the info. I'm new to all this, and us old guys are slow learners. . |
damn that's a sharp car!!!!:smokin: :smokin: :smokin: |
| All times are GMT -4. The time now is 01:30:53 AM. |
