NastyZ28.com
NastyZ28.com (http://www.nastyz28.com/forum/index.php)
-   Body Restoration (http://www.nastyz28.com/forum/forumdisplay.php?f=10)
-   -   What to use to seal rear spoiler holes??? (http://www.nastyz28.com/forum/showthread.php?t=210398)
ChevyReb 03-27-2011 03:48:42 PM
What is best product to use to seal the spoiler mounting holes in the deck lid and 1/4's?
krabben1 03-27-2011 04:34:23 PM
Seam sealer mang.Or leftover window install strip.
ChevyReb 03-27-2011 04:47:58 PM
^^^what kind if you use the 3M 8308 stuff it will never come back off!!!! :eek::eek::eek::screwup:
boardog 03-27-2011 04:56:00 PM
amk kit, comes with new hardware and rubber washers
https://www.amkproducts.com/shopping_cart/view_cart.asp
ChevyReb 03-27-2011 04:58:11 PM
Ken that link will not work do you have the item or part number? Thanks a ton!
boardog 03-27-2011 06:57:03 PM
part # g-4166 12.00 comes with the correct nuts and rubber washers.
ChevyReb 03-27-2011 07:19:50 PM
Thanks Ken,
Just checked my body bolt kit I ordered from them and danged if that was not in there so I already had it...Kool! I forgot how much stuff came in that kit. I even have the chrome bumper bolts and the Z28 fang well nuts and bolts too.
so do you use any seam sealer on the rubber gaskets or is that all you need?
Thanks for your help and effort!!!
blades67 03-27-2011 07:21:38 PM
That kit is $12 and that company has $30 minimum order amount.
boardog 03-27-2011 09:01:48 PM
i just use the washers, i buy a kit for every car i do. the amk kit is the best i have found.
earlysecond 03-27-2011 09:45:35 PM
A 3M product called Strip Caulking. Hopefully your are able to close some of the gaps up with the right stuff. I apply a bit of this everywhere else. So many uses it is well worth the price of admission!
krabben1 03-27-2011 11:11:02 PM
Just a heads up for anyone wanting to use these.Lowes carries these in their hardware section.I bought a few of them a few months ago,but used them on the underside for the mounting nuts as not to scratch my trunklid.(I knew the spoiler was coming back off)Theyre dirt cheap too.
71 Camaro 03-28-2011 10:10:59 AM
linky no worky
79ws6resto 03-28-2011 10:39:54 AM
Agreed
FlaJunkie 03-28-2011 10:42:25 AM
I use this a lot, too. So far, I have reinstalled the kick panels and outside heater box cover with this stuff. I have more places to use it, including the spoiler holes!
Rene Melten 03-28-2011 11:29:07 AM
Part # G-4166. 3 piece spoiler, wasn't too hard to find.;)
https://www.amkproducts.com/GM_Fastener_Kits.asp
